HI,1、If natural ventilation is turned on, the air conditioning system will be turned on accordingly according to the setting of natural ventilation. Of course, it needs to set a parameter setting matching the air conditioning system and natural ventilation.2.you can select Output:Variable or meter to calculate the heating load. If you encounter software problems at work, please contact me. Wechat: xiang_zhong_meng
HI,1、If HI,
1、If natural ventilation is turned on, the air conditioning system will be turned on accordingly according to the setting of natural ventilation. Of course, it needs to set a parameter setting matching the air conditioning system and natural ventilation.2.you ventilation.
