Solution found, largely related to this other Unmet hours post: link text
However, I had to adjust the Maximum Outdoor Temperature in Heating Mode well above what Richard recommend (26.5C). I ended up with a 38C input in this field for the heating coil to turn on.
However, I had to adjust the Maximum Outdoor Temperature in Heating Mode well above what Richard recommend recommended (26.5C). I ended up with a 38C input in this field for the heating coil to turn on.
