I'm having the same problem.
I've removed and reinstalled sketchup 2020 and Openstudio application 1.3.0. Run a repair on the Sketchup install, and deleted all the User/appdata directories.
I'm running Win 10 64 bit.
Using file manager>copy path I get: "C:\openstudioapplication-1.3.0\Ruby\openstudio_modeleditor.so"
The error message Is
So the file is there.
The file manager path uses back slashes and the error message foward slashes. Could this be the problem? I've tried editing the path to the OpenStudio root directory in the sketchup dialog that pops up on startup to use a backslash but this doesnt have any effect.
Any help would be greatly appreciated.
Update I removed OpenStudio application 1.3.0 and installed 1.1.0 and everything is working fine now.
So in myinstance at lease Sketchup pro 2020 and OS application 1.3.0 are not working together but 2020 aand 1.1.0 are working.
