On the thermal zones tab you can choose the cooling and heating sizing parameters subtabs. There you will find the Design Zone Air Distribution Effectiveness either for cooling or heating. See also the attached picture. This way you will create a DesignSpecification:ZoneAirDistribution object
On the thermal zones tab you can choose the cooling and heating sizing parameters subtabs. There you will find the Design Zone Air Distribution Effectiveness either for cooling or heating. See also the attached picture. This way In the translation you will create a DesignSpecification:ZoneAirDistribution object
