Are you familiar with the Surface Search utility? It's a button that looks like a funnel within Sketchup as part of the Openstudio Tools toolbar. This toolbar is turned on by going to the View menu>Toolbars and selecting Openstudio Tools toolbar.
More information on the Inspector and Surface Search utility can be found here under Sketchup Plugin, Information Tools: http://nrel.github.io/OpenStudio-user...
An example regarding functionality is in this thread: "How to model underground floors in Openstudio"
More information on the Inspector and Surface Search utility can be found here under Sketchup Plugin, Information Tools: http://nrel.github.io/OpenStudio-user...http://nrel.github.io/OpenStudio-user-documentation/
| 4 | No.4 Revision |
More information on the Inspector and Surface Search utility can be found here under Sketchup Plugin, Information Tools: http://nrel.github.io/OpenStudio-user-documentation/http://nrel.github.io/OpenStudio-user-documentation/reference/sketchup_plugin_interface/#information-tools
| 5 | No.5 Revision |
More information on the Inspector and Surface Search utility can be found here under Sketchup Plugin, Information Tools: http://nrel.github.io/OpenStudio-user-documentation/reference/sketchup_plugin_interface/#information-tools
An example regarding functionality is in this thread: "How to model underground floors in Openstudio"Openstudio" here
