Not as of right now. OpenStudio translate the Space objects inside a ThermalZone as a single EnergyPlus Zone. You need to put each Space into a separate ThermalZone.
Not as of right now. OpenStudio translate translates the Space objects inside a ThermalZone as a single EnergyPlus Zone. You need to put each Space into a separate ThermalZone.
