An alternative to OpenStudio (application and SketchUp plug-in) that reads and writes OSM files that eventually are translated to IDF files is Euclid, another SketchUp plug-in formerly known as Legacy OpenStudio that reads and writes to IDF files directly. Using Euclid, you can:
BuildingSurface:Detailed object that Julien mentioned for all drawn surfaces.[Floor:Adiabatic object](https://bigladdersoftware.com/epx/docs/9-6/input-output-reference/group-thermal-zone-description-geometry.html#flooradiabatic) and similar "simpler" surface objects in Julien's list above. Euclid will translate these "simpler" surface objects into BuildingSurface:Detailed objects. | 2 | No.2 Revision |
BuildingSurface:Detailed object that Julien mentioned for all drawn surfaces.[Floor:AdiabaticFloor:Adiabatic BuildingSurface:Detailed objects. | 3 | No.3 Revision |
BuildingSurface:Detailed object that Julien mentioned for all drawn surfaces.Floor:Adiabatic object and similar "simpler" surface objects in Julien's BuildingSurface:Detailed objects.
