I am able to reproduce the bug and have filed an EnergyPlus bug report. In the meantime, you'll have to use the Correlation input and obtain the two input parameters yourself from the weather file or stat file.
I am able to reproduce the bug and have filed an EnergyPlus bug report. In the meantime, you'll have to use the Correlation input calculation method and obtain the two input parameters yourself from the weather file or stat file.
