No, not during the simulation ehere it's being sized. However, after completing an initial simulation, the maximum water flow rate is listed in the output reports, including the database/SQL file (if requested). You can then run the simulation a second time, and this time you can query the sql file from the first simulation (assuming you saved a copy) in your Python script to pull the sized capacities/flow rates.
No, not during the simulation ehere where it's being sized. However, after completing an initial simulation, the maximum water flow rate is listed in the output reports, including the database/SQL file (if requested). You can then run the simulation a second time, and this time you can query the sql file from the first simulation (assuming you saved a copy) in your Python script to pull the sized capacities/flow rates.
