You can use the Python Plugin release with version 9.3 to get the handle of the occupancy schedule and run all the simulations that you want.
You can use the Python Plugin release released with version 9.3 versions 9.3, 9.4, and 9.5 to co-simulate with EP. What you need to do is get the handle of the occupancy schedule and then change the occupancy variable in python. By doing so, you can run all the as many simulations that as you want.
