You might try increasing the Maximum Number of Warmup Days. As the EnergyPlus documentation states:
This field specifies the number of “warmup” days that might be used in the simulation before “convergence” is achieved. The default number, 25, is usually more than sufficient for this task; however, some complex buildings (with complex constructions) may require more days.
