I have the same question. From this section of the Input/Output reference, it seems that we should be able to request the "Heating Coil Water Heating Electricity Energy" whenever there's a Coil:WaterHeating:AirToWaterHeatPump:Pumped in the model. But it's not available for some reason when the heating coil is a part of the heat pump water heater. I opened an issue on the EnergyPlus GitHub with a sample IDF file and, hopefully, we can get confirmation if this is the expected behavior.
