The seed model can be empty if you are planning to run an OpenStudio measure that essentially creates the entire model from scratch. Here is an example of an empty seed model. You probably should update the version to match the version of OpenStudio you are using.
The seed model can be empty if you are planning to run an OpenStudio measure in PAT that essentially creates the entire model from scratch. Here is an example of an empty seed model. You probably should update the version to match the version of OpenStudio you are using.
