Here is an expression example that sets WINDOW:HEIGHT based on the parent keyword EXTERIOR-WALL:DEG-FROM-NORTH and other global parameters. This could just as easily be written using if statements with ranges for the resulting angle.
HEIGHT =
{ switch (#p("DEG-FROM-NORTH"))
case 315 : (#pa("L6GlzgHt_North")*#pa("ResAWWGlzgMult"))
case 225 : (#pa("L6GlzgHt_East")*#pa("ResAWWGlzgMult"))
case 135 : (#pa("L6GlzgHt_South")*#pa("ResAWWGlzgMult"))
case 45 : (#pa("L6GlzgHt_West")*#pa("ResAWWGlzgMult"))
default : 0.0
endswitch
The DEG-FROM-NORTH property is documented in the DOE-2.2 help, and is populated using the #CDN BDL function. Here is the expression for the property located in BDLdft.dat:
DEG-FROM-NORTH
{#CDN(#L("AZIMUTH")+#P("AZIMUTH")+#P2("AZIMUTH")+
#G("BUILD-PARAMETERS","AZIMUTH"), #L("TILT"))}
For buildings that will be rotated, the resulting DEG-FROM-NORTH value may need to be adjusted to compensate for the rotation.
