Ok, bear with me because by default those logs are hidden pretty bad.
I am assuming you are running Windows, in which case it will be in you App Data TEMP folder in C:\Users\{YOUR_USERNAME}\AppData\Local\Temp\. The log is deleted if you exit the interface in OpenStudio. So:
The file is going to be in a directory named something like osmodel-1632432699-1\ApplyMeasureNow\run\000_83e77929-f391-407a-8aef-20994f5b7e37, and the other simulation files will be there.
Mark as solved if helpful!
