It appears this is an issue with OpenStudio itself. Your file appears to be valid gbxml (at least with respect to the Schedules).
I've opened an issue at NREL/OpenStudio#4439 and will address it shortly. Follow the issue for updates.
Edit: Should be addressed via https://github.com/NREL/OpenStudio/pull/4440
