The CoilSystem object is set point controlled. When a scheduled set point manager is used, the set point is not affected by the thermostat temperature. You could use a SetpointManager:SingleZone:Cooling object to control the coil where the thermostat would be used.
SetpointManager:Scheduled,
Scheduled Deck Temp 121, !- Name
Temperature, !- Control Variable
Deck Temperature, !- Schedule Name
Node 1590; !- Setpoint Node or NodeList Name
