If you really need to control only a htg/clg power supplied to a space, you can use an OtherEquipment obj and then control the EMS actuator
EnergyManagementSystem:Actuator Available, *,OtherEquipment,Power Level,[W]
You can set convective/radiant fraction to simulate some kind of terminal units;
positive numbers stand for heat gain to the zone --> heating like
negative numbers stand for heat losses to the zone --> cooling like
Ag
