I found this on bigladder website and my problem is solved:
Zone Heating Setpoint Not Met While Occupied Time: Hours when the zone temperature is lower than 0.2 (default) degrees C below the heating setpoint and when people are present in the zone. To change the reporting range from 0.2 degrees C, see the OutputControl:ReportingTolerances object.
