The heating and cooling capacity, and therefore the heat transfer, are a function of the load and source temperatures and air/water flow rate "ratios". Check that the performance curves used actually change the performance curve output if air flow is different from rated conditions.
HeatCapRated = SimpleWatertoAirHP(HPNum).RatedCapHeat;
QLoadTotal = HeatCapRated *
CurveValue(state, state.dataWaterToAirHeatPumpSimple->SimpleWatertoAirHP(HPNum).HeatCapCurveIndex, ratioTDB, ratioTS, ratioVL, ratioVS);
CurveValue(state, state.dataWaterToAirHeatPumpSimple->SimpleWatertoAirHP(HPNum).HeatCapCurveIndex, SimpleWatertoAirHP(HPNum).HeatCapCurveIndex, ratioTDB, ratioTS, ratioVL, ratioVS);
