Go to this link.
https://github.com/NREL/resstock/releases
Find the version you want to use. If you are using OpenStudio/PAT rather than .yml files to set up your simulation, you should select version 2.2.5, which is the most recent version supported as a PAT project. I have a lot of experience setting up ResStock v2.2.5 and prior, but not so much experience with v2.3.0 and v2.4.0, which do not use PAT.
Click on the version you want and then click on Source code (zip) to download.
Copy your download to desktop, unzip the files, and open up the project_singlefamilydetached folder as an existing project in PAT.
