If there are repeating floor plates of same/similar lay out, then a floor multiplier could be used. This is especially helpful in a building/site with multiple of the same floors.
For the unique floor plate or areas, those need to be modeled individually.
If there are repeating floor plates of same/similar lay out, then a floor multiplier could be used. This is especially helpful in a building/site with multiple of the same floors.floors (same envelope, same interior loads, same schedules. same HVAC).
For the unique floor plate or areas, those need to be modeled individually. individually.
