Actually they ARE visible in the Measures tab:
But if you go to the top window menu, hit Measures, then Apply Measure Now, the resulting screen doesn't work
Update: Matthew pointed out that the screen I was trying to use is just for OS measures, not for E+ measures.
tab:
Actually they The other kinds of measures ARE visible in the Measures tab:
