As mentioned in comments you can get plug loads and lighting in OpenStudio Results. If heating and cooling energy transfer (and not energy consumption) is fine for your study that is in the Annual and Peak Values - Other report in the EnergyPlus epllustbl.html file under the Energy Meters section.
If you wanted to get consumption you could but that may take a custom report using annual or monthly output variables for the required components. You would have to decide if you wanted to look at fans consumption as well.
