This may be because of the architecture of your laptops. If your are running the 64bit version of E+ (on a 64-bit machine) and you are trying to import an FMU that is only containing 32-bit binaries then the import won't work and vice-versa. You should hence unzip your FMU and see in its binaries folder the libraries which are included so you know the architecture required for the import.
