I have been using ResStock for the past year! I use OS v2.9.0 as well! I can help you install it, maybe we can set up a video call.
I have been using ResStock v2.2.4 for the past year! I can't help you with any of the newer versions of ResStock that don't use the ParametricAnalysisTool (PAT), so everything after v2.2.5 I don't have experience with. You should download v2.2.5, since that has a few minor differences from v2.2.4 but still follows the same framework. I use OS v2.9.0 as well! I can help you install it, maybe we can set up a video call.
I have been using ResStock v2.2.4 for the past year! I can't help you with any of the newer versions of ResStock that don't use the ParametricAnalysisTool (PAT), so (PAT); everything after v2.2.5 I don't have experience with. You should download v2.2.5, since that has a few minor differences from v2.2.4 but still follows the same framework. I use OS v2.9.0 as well! I can help you install it, maybe we can set up a video call.
| 4 | No.4 Revision |
I have been using ResStock v2.2.4 for the past year! I can't help you with any of the newer versions of ResStock that don't use the ParametricAnalysisTool (PAT); everything after v2.2.5 I don't have experience with. You should download v2.2.5, since that has a few minor differences from v2.2.4 but still follows the same framework. I use OS v2.9.0 as well! I can help you install it, maybe we can set up a video call.
