Additional methods for removing EMS objects:
model.getEnergyManagementSystemActuators(&:remove)
model.getEnergyManagementSystemConstructionIndexVariables(&:remove)
model.getEnergyManagementSystemCurveOrTableIndexVariables(&:remove)
model.getEnergyManagementSystemGlobalVariables(&:remove)
model.getEnergyManagementSystemInternalVariables(&:remove)
model.getEnergyManagementSystemMeteredOutputVariables(&:remove)
model.getEnergyManagementSystemOutputVariables(&:remove)
model.getEnergyManagementSystemPrograms(&:remove)
model.getEnergyManagementSystemProgramCallingManagers(&:remove)
model.getEnergyManagementSystemSensors(&:remove)
model.getEnergyManagementSystemSubroutines(&:remove)
model.getEnergyManagementSystemTrendVariables(&:remove)
Credit to @Scott Horowitz from NREL.
You could also extend the solution provided by @Eric Martin to multiple EMS objects.
# remove EMS objects model.getEnergyManagementSystemSensors.each do |ems_obj| ems_obj.remove end model.getEnergyManagementSystemActuators.each do |ems_obj| ems_obj.remove end model.getEnergyManagementSystemGlobalVariables.each do |ems_obj| ems_obj.remove end
etc... for other EMS objects
