Regarding your question on estimating energy consumption with respect to people's occupancy, you can look at the people object here: https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-internal-gains-people-lights-other.html#people.
The actual occupancy, as a function of time (i.e. at each timestep), in a thermal zone that has been assigned a people object statement is calculated through multiplication as described below.
The Number of People Schedule "values can be any positive number," and the "actual number of people in a zone as defined by this statement is the product of the number of people field and the value of the schedule specified by name in this field."
So, some steps for you are to:
https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-internal-gains-people-lights-other.html#field-zone-or-zonelist-name-000
https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-internal-gains-people-lights-other.html#field-number-of-people-calculation-method
https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-internal-gains-people-lights-other.html#field-number-of-people-schedule-name
In this occupancy schedule, you can specify if your building is occupied from 8 am - 5 pm (working hours), after hours, etc. If occupancy changes throughout the day (is your building more heavily occupied in the morning vs afternoon?) you can implement this by specifying the actual values of the schedule referenced by the Number of People Schedule Name field at each timestep.
You can also distinguish between weekdays vs weekends vs holidays using the schedule object.
"Note that while the schedule value can vary from hour to hour, the number of people field is constant for all simulation environments."
In order to determine the impact of people occupancy on energy consumption, try plotting the occupancy (nominal occupancy*schedule fraction) in each zone with kWh of electricity for different end-use subcategories (lights, space conditioning, etc.). Try changing the nominal occupancy value for each thermal zone or the schedule fractions to see how that impacts your model.
