@Rwadhwa910 It appears there is an orphan sub-surface in the geometry for the prototype secondary school used for the measure. If you run the measure to remove orphan objects it will remove this. I have an issue filed about the orphan surface.
Follow advise on this post to change exterior door logic argument to Remove Doors
until the issues with splitting base surfaces at doors can be resolved.
