There are two version of the Type534 proforma. One uses a plugin application to allow user input of all of the component parameters (Version with Plug-in) and another that allows direct user input of a somewhat limited set of component parameters (Version without Plug-in). If you are using the version with the Plug-on you need to click the button on the lower left of the proforma window to activate the plugin (See Section 2.12.8.1 of the SimulationStudio volume of the TRNSYS documentation set).
