I searched patiently and found one basis of escalator schedules.
ANSI/ASHRAE/IES Standard 90.1-2016 Performance Rating Method Reference Manual states:
NACM(Nonresidential Alternative Calculation Method) issued by CEC(California Energy Commission) describes Schedules in Section 5.4 Space Uses as follows:
Appendix 5.4B is here. I put the downloaded excel files here in case the link to the website breaks.
In Appendix 5.4B, elevator schedules and escalator schedules are specified separately for each building type, and the escalator schedules consist of a fraction of 0 or 1. The following table shows only the escalator schedules for each building type I extracted from Appendix 5.4B.
I just updated the summary table of escalator schedules above as I found the schedule for Restaurant was incorrect. The original NACM Appendix 5.4B is correct.
