You need to modify RunEplus.bat so that it references the correct directories to locate your IDF, EPW, and EnergyPlus installation files. Right click + edit on RunEplus.bat and it will open in a text editor. Modify the paths highlighted below as appropriate, then in command prompt: RunEPlus.bat in in (assuming in.idf and in.epw filenames).
