The High-Rise Apartment prototype model already utilizes water-source heat pumps, so I believe you just want to add a ground heat exchanger to the condenser water plant loop (Single Water Plant Loop). You may also want to remove the existing boiler and fluid cooler from the Plant Supply Side Branches if you want the ground to provide all source water heating/cooling, or you could keep the existing equipment to provide supplemental capacity. Implementing GSHP on the mid-rise apartment model is more involved because the prototype does not already contain a plant loop or utilize water-source HP coils, so you would need to rebuild the entire HVAC system. I haven't used the OS measures you referenced so I don't know why those aren't working.
The High-Rise Apartment prototype model already utilizes water-source heat pumps, so I believe you just want to add a ground heat exchanger to the condenser source water plant loop (Single Water Plant Loop). You may also want to remove the existing boiler and fluid cooler from the Plant Supply Side Branches if you want the ground to provide all source water heating/cooling, or you could keep the existing equipment to provide supplemental capacity. Implementing GSHP on the mid-rise apartment model is more involved because the prototype does not already contain a plant loop or utilize water-source HP coils, so you would need to rebuild the entire HVAC system. I haven't used the OS measures you referenced so I don't know why those aren't working.
