The standard way to do this is to use the weather converter that comes with EnergyPlus to create a "EnergyPlus CSV" file. Then, make your changes -- FYI, you should change dewpoint to missing (99.9) and relative humidity to some number (100?).
Then, use the weather converter again to change the EnergyPlus csv format to an EPW.
Linda
FIBPSA, FASHRAE http://climate.onebuilding.org - free repository of climate data for building simulation Climate.onebuilding is a FREE service not supported by any outside organization or government agency.
