There are some really great sites that you can purchase files. Some sites include pre-formated files for .epw, .bin, etc. The cost ranges from about $15-75 for a year of data. These include typical meteorological years, actual meteorological years, etc. In my opinion it is totally worth it to just purchase the file. Sometimes when you download free data (from say NCDC or energyplus real-time data, which I think is the same source), there can be gaps, errors, missing data, etc. which can take hours to clean up. I just downloaded a file for 2013 in downtown los angeles and for $40 bucks was able to get the following file formats (AMY.bin, AMY.txt/.csv, AMY.epw, AMY.stat, AMY.tm2, AMY.tm3). It took about 1 hour from the time I purchased to get the file. TOTALLY WORTH IT. I won't post the names for the sites, but do a keyword search and you should be able to find something fairly quick.
The cost ranges from about $15-75 15-75 dollars for a year of data. These include typical meteorological years, actual meteorological years, etc.
In my opinion it is totally worth it to just purchase the file. Sometimes when you download free data (from say NCDC or energyplus real-time data, which I think is the same source), there can be gaps, errors, missing data, etc. which can take hours to clean up. I just downloaded a file for 2013 in downtown los angeles and for $40 bucks 40 dollars and was able to get the following file formats (AMY.bin, AMY.txt/.csv, AMY.epw, AMY.stat, AMY.tm2, AMY.tm3). It took about 1 hour from the time I purchased to get the file. TOTALLY WORTH IT. I won't post the names for the sites, but do a keyword search and you should be able to find something fairly quick.
