Another approach is to use the Output:Table:Annual object, which offers a lot of flexibility for how information is reported. For example, you can specify the Output:Variable of interest and choose Maximum for the Aggregation Type.
If you want the maximum of an EMS variable instead of a built-in E+ output, you just need one additional step where an EnergyManagementSystem:OutputVariable references the EMS variable -- then it can be used in an Output:Variable for the above approach.
