Depending on the type of cooling equipment you are using, you might be looking for Output:Meter,CoolingCoils:EnergyTransfer or Output:Meter,Cooling:EnergyTransfer, both of which are reported in Joules. Check out the I/O reference page on Output:Meter. If you want to combine meters, check out Meter:Custom page.
