You are not clear about which version of TRNSYS you are using, but it looks like you have access to the TESS Libraries. For the storage tanks I would recommend using Type534 from the TESS Storage Tank Component Library. Also make sure that the data file used to determine the ASHP performance matches the behavior of the ASHP that you are attempting to model.
