If by multiple heat pumps, you are referring to more than one heating/cooling system for a single building/zone, then, as far as I know, you cannot do it in BEopt. If you want to use the analysis for sizing purposes, you can still take the total size and assume it is provided by multiple heat pumps with smaller sizes. Also, you can define a supplemental heating output capacity (more information here).
