First, check if the Adaptive Comfort Summary report in eplustbl.htm is populated. If the table is empty, check if you still have cooling on in your model. If the numbers are there, use the CSV method (available in jEPlus v2) rather than SQL. It is a lot easier. The relevant manual is here: https://www.jeplus.org/wiki/doku.php?id=docs:jeplus:v21:rvx#csvs_-_e_tabular_report
Edit:
As per the comments below, it turned out that in eplustbl.csv, the column headers can have extra spaces between words, which is not visible in Html form. So if you follow the video tutorial and copied the texts from eplustbl.htm, and it did not work, do that again using eplustbl.csv may solve the problem.
