Since the OpenStudio SDK simply provides methods to modify EnergyPlus inputs, you should consult the EnergyPlus documentation for descriptions/units/etc. for the inputs themselves.
For example, here is the Rated Air Flow Rate documentation for the Coil:Cooling:DX:SingleSpeed object.
