You linked to the documentation for the Coil:Cooling:WaterToAirHeatPump:VariableSpeedEquationFit object instead of the Coil:Cooling:WaterToAirHeatPump:EquationFit object. Here is the documentation for the latter:
https://bigladdersoftware.com/epx/docs/8-2/input-output-reference/group-heating-and-cooling-coils.html#coilcoolingwatertoairheatpumpequationfit
You can also find more information on the curves in the Engineering documentation:
https://bigladdersoftware.com/epx/docs/8-2/engineering-reference/air-system-compound-component-groups.html#single-speed-equation-fit-model
