Rather than including "None" in your options try using "Exhaust only". While older homes will likely lack the automated controls that trigger bath fans to run, this scenario is something that the system can reasonably trade-off versus low infiltration + HRV/ERV.
Rather than including "None" in your options try using "Exhaust only". While older homes will likely lack the automated controls that trigger bath fans to run, this scenario is something that the system optimizing engine can reasonably trade-off versus low infiltration + HRV/ERV.
