It looks like the measure has not been updated to reflect changes in EnergyPlus v9.4. The measure.rb file has a reference to "Gas:Facility" that should be "NaturalGas:Facility". Try changing that one line of code and see if it helps.
It looks like the measure has not been updated to reflect changes to fuel names in EnergyPlus v9.4. recent versions of EnergyPlus. The measure.rb file has a reference to "Gas:Facility" that should be "NaturalGas:Facility". Try changing that one line of code and see if it helps.
