Thermal and solar absorptances are only used when appropriate - they're ignored otherwise, see : Input Output Reference. If uncertain, stick to the default values e.g., 0.9 (thermal) or 0.7 (solar).
![]() | 2 | No.2 Revision |
Thermal and solar absorptances are only used considered in EnergyPlus when appropriate - they're appropriate. For instance when a material surface sees the outside environment, other interior surfaces, etc. Otherwise, those attributes are ignored otherwise, see : at run time, as in the case of conductive heat flow between 2 materials. See: Input Output Reference. If uncertain, stick to the default values e.g., 0.9 (thermal) or 0.7 (solar).
