The only issue I see from the sample idf file you posted is the semi-colon ";" placement. If you want to include the visible transmittance value then it should look like this (without using "!" that comments out this part):
WindowMaterial:SimpleGlazingSystem,
Glass, !- Name
1.817152, !- U-Factor {W/m2-K}
0.4, !- Solar Heat Gain Coefficient
0.88; !- Visible Transmittance
If you don't want to consider the transmittance value, the TV should be commented using "!" and the semi colon ";" should be placed after the SHGC value (i.e., 0.4) to end the object as shown below:
Glass, !- Name
0.4; !- Solar Heat Gain Coefficient
! 0.88; !- Visible Transmittance
