EnergyPlus can generate these hourly output variables, but it won't tell you specific like peak-hour values. Sounds like you need to set up a script using Python, Ruby, or something similar to do multiple steps:
EnergyPlus can generate these hourly output variables, but it won't tell you specific specifics like peak-hour values. Sounds like you need to set up a script using Python, Ruby, or something similar to do multiple steps:
