The fact that you are having to manually add the building type the the measure is an indication that it isn't the correct version of the measure. Try the copy of the measure in the 0.3.0 version fo the model articulation gem. You can get this by installing the Ruby gem or by checking out the GitHub repository. In either case use your my measures directory to access the measure from the OpenStudio Application.
The fact that you are having to manually add the building type the the measure is an indication that it isn't the correct version of the measure. Try the copy of the measure in the 0.3.0 version fo of the model articulation gem. You can get this by installing the Ruby gem or by checking out the GitHub repository. In either case use your my measures directory to access the measure from the OpenStudio Application.
