|  1 |    initial version    |
Could you use an older version of the OpenStudio application that generates IDFs for EP v9.2? That would be OpenStudio application v2.9 which would avoid the need to "downgrade" the exported IDF which is a process that doesn't seem to currently have a tool to automate. The third comment for the second answer near the bottom of this post discusses how to manually downgrade an IDF using the IDD file for each EP version.
