Thanks so much for your advice - thats super helpful. I did as you recommended and tried to find every 'OpenStudio' case in the .json there. I removed:
and then:
and also:
that seemed to work well and allowed me to get Sketchup up and running, and I could go to the Extension Warehouse and try and reinstall the OpenStudio plugin - that worked and I was able to get as fas as tagging the OpenStudio folder:
but when I input the folder location (on my computer it is: /Applications/OpenStudioApplication-1.1.0/ ) it crashes on me. I get a 'BugSplat' report but no other information this time (no detailed crash report?)
is there maybe another location that I need to clean out / remove in addition that you can think of that might be causing this?
if its helpful, this is a copy my current/edited PrivatePreferences.json file: https://www.dropbox.com/s/pyk2ui1ybksxjo2/PrivatePreferences.json?dl=0
and my current Sketchup directory looks like this:
any advice or other thoughts or recommendations you might have are much appreciated!
thanks so much,
-Ed
